Ga door naar hoofdinhoud
Replacing a TAE/DSL Socket with a RJ45 Jack
Wat je nodig hebt
  1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: stap 1, afbeelding 1 van 2 Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: stap 1, afbeelding 2 van 2
    • Unscrew and remove the cover.
    • If you want to add a RJ45 jack but only have the first outlet, that you can’t replace, to work with, you can just mount the new outlet next to the old one. You’ll need to connect La to 6 and Lb to 5. You can use any kind of shielded twisted pair cable to wire the new outlet.
    • Remove the the connections.
    • Keep track of La and Lb. You’ll need to know what wires to connect where in the new socket.
    • Unscrew the socket from the wall.
  2. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the new socket: stap 2, afbeelding 1 van 1
    • Screw the new socket cover to the wall.
    • Refer to the manual that came with your outlet for this step.
  3. Replacing a TAE/DSL Socket with a RJ45 Jack, Punch down the wires: stap 3, afbeelding 1 van 1
    • If you don’t know how to use a punch down tool, give this guide a look.
    • Connect La to pin 4 (Blue).
    • Connect Lb to pin 5 (White-Blue).
  4. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the socket: stap 4, afbeelding 1 van 1
    • Mount the RJ45 socket inside the case and screw on the faceplate.
Conclusie
Have fun surfing the web!
Sebastian Dorr
16.166 Reputatie
57 handleidingen geschreven
German Translators Lid van German Translators
Community
19 Leden
677 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 167
Altijd: 493
