Ga door naar hoofdinhoud
How to use a Krone LSA-Plus Punchdown Tool
Wat je nodig hebt
  1. How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: stap 1, afbeelding 1 van 2 How to use a Krone LSA-Plus Punchdown Tool, LSA vs. LSA Plus: stap 1, afbeelding 2 van 2
    • There is a difference between LSA and LSA Plus:
    • LSA: The insulation displacement terminals are perpendicular to the cable.
    • LSA Plus: With this technology, the insulation displacement connectors are at an angle of 45° to the cable.
  2. How to use a Krone LSA-Plus Punchdown Tool, Switch the scissors on/off: stap 2, afbeelding 1 van 1
    • The Krone tool has integrated scissors that automatically cut the excess when you punch down the wire.
    • To enable or disable the scissors, turn the wheel in the middle of the tool.
  3. How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: stap 3, afbeelding 1 van 2 How to use a Krone LSA-Plus Punchdown Tool, Switch the sensor on/off: stap 3, afbeelding 2 van 2
    • The sensor is a mechanism that only allows the scissors to work if the tool is properly inserted into the LSA slot. You might want to disable it if you want to connect two wires on one contact (requires special contact).
    • To disable the sensor, move the metal bracket at the front of the tool towards the toolhead.
  4. How to use a Krone LSA-Plus Punchdown Tool, Place your cable: stap 4, afbeelding 1 van 1
    • Place the cable you want to punch down into the terminal.
  5. How to use a Krone LSA-Plus Punchdown Tool, Punch down: stap 5, afbeelding 1 van 2 How to use a Krone LSA-Plus Punchdown Tool, Punch down: stap 5, afbeelding 2 van 2
    • Press down on the connector.
    • LSA-Plus is directionally keyed. If your tool doesn't enter into the gap, it might be because you're holding it the wrong way around.
  6. How to use a Krone LSA-Plus Punchdown Tool, Cut the excess: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Flush Cutter
    $29.99
    Koop
    • If your scissors are off, or you're working in a tight space where the excess left by the tool might be too much you'll have to manually trim the excess.
    • Use electronics sidecutters to trim the excess.
  7. How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: stap 7, afbeelding 1 van 3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: stap 7, afbeelding 2 van 3 How to use a Krone LSA-Plus Punchdown Tool, Remove a connection: stap 7, afbeelding 3 van 3
    • Press on the tab to release the wire removal hook.
    • Use the hook to pull out the wire you want to remove.
Conclusie
Good luck on your next project!
Sebastian
20.933 Reputatie
60 handleidingen geschreven
German Translators Lid van German Translators
Community
27 Leden
751 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 80
Afgelopen 30 dagen: 285
Altijd: 2,203
