Ga door naar hoofdinhoud
Replacing a Nintendo GameCube Controller Stickbox
Wat je nodig hebt
  1. Replacing a Nintendo GameCube Controller Stickbox, Stickbox: stap 1, afbeelding 1 van 2 Replacing a Nintendo GameCube Controller Stickbox, Stickbox: stap 1, afbeelding 2 van 2
    • Using the Tri-Wing, remove the six 9.2mm Tri-wing Y0 screws at the back of the controller
  2. Replacing a Nintendo GameCube Controller Stickbox: stap 2, afbeelding 1 van 1
    • Remove the backplate with the motherboard and take out the motherboard.
    • Removing it this way will make it easier to reassemble later on.
  3. Replacing a Nintendo GameCube Controller Stickbox: stap 3, afbeelding 1 van 2 Replacing a Nintendo GameCube Controller Stickbox: stap 3, afbeelding 2 van 2
    • Unhook the two trigger wires on the black plastic piece.
    • Unhook the rumble motor wire.
    • Be careful with the motor wires, they are fragile.
    • Turn the motherboard around and push the two black pins down to unlock the plastic piece.
  4. Replacing a Nintendo GameCube Controller Stickbox: stap 4, afbeelding 1 van 2 Replacing a Nintendo GameCube Controller Stickbox: stap 4, afbeelding 2 van 2
    • Take out the rumble motor from the black piece.
    • Be careful with the rumble wires, they are fragile.
    • Slide the two triggers forward and the black piece is now removable.
  5. Replacing a Nintendo GameCube Controller Stickbox: stap 5, afbeelding 1 van 2 Replacing a Nintendo GameCube Controller Stickbox: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Desoldering Pump
    $3.99
    • Set your soldering iron to around 420c.
    • Using your soldering iron and desoldering pump, remove the 10 pins and take out the stick box.
    • There might be some solder left making it hard to pull out. Use of a flat hard object to help push the pins out might be necessary.
  6. Replacing a Nintendo GameCube Controller Stickbox: stap 6, afbeelding 1 van 3 Replacing a Nintendo GameCube Controller Stickbox: stap 6, afbeelding 2 van 3 Replacing a Nintendo GameCube Controller Stickbox: stap 6, afbeelding 3 van 3
    • Line up and insert the new stick box.
    • Resolder the 10 pins.
    • Make sure there is no connection between the pins
Conclusie
GameCube controllers are still actively used in competitive Smash Bros and as well as retro gaming. They are usually hard to purchase brand new as supplies run out fast or must be bought used from third-party resellers. The stick can be swapped with each other on a controller or with even a Wii Nunchuck.
3 andere personen hebben deze handleiding voltooid.
Terry Poon
223 Reputatie
1 Handleiding geschreven
2Gids Commentaar
This is only for t1 and t2 stickboxes. The new t3 stickboxes, used sience 2008 use JIS 0 screws.
Meow Purr - Antwoord
Will the stickbox of a Classic Controller fit?
Gabriel Resende - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 111
Altijd: 9,552
