Ga door naar hoofdinhoud
Replacing VTech MobiGo Touch Learning System Speaker
Wat je nodig hebt
    1. Replacing VTech MobiGo Touch Learning System Speaker, Case: stap 1, afbeelding 1 van 1
      • Remove the battery covers and the four batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing VTech MobiGo Touch Learning System Speaker: stap 2, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker: stap 2, afbeelding 2 van 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing VTech MobiGo Touch Learning System Speaker: stap 3, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker: stap 3, afbeelding 2 van 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: stap 4, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: stap 4, afbeelding 2 van 2
      • The speaker will be attached to the back of the case.
      • Unscrew the two 6.0 mm Philips J0 screws.
      • Careful! The wires are still attached to the back of the case and to the speakers.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing VTech MobiGo Touch Learning System Speaker: stap 5, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker: stap 5, afbeelding 2 van 2
      • Lift the round speaker with a plastic opening tool.
      • Remove the two wires connected to the speaker.
      • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
      • Once the wires are disconnected, remove the speaker from the back of the case.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing VTech MobiGo Touch Learning System Speaker: stap 6, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker: stap 6, afbeelding 2 van 2
      • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
      • The wires may be hot.
      Vraag FixBot
      Voeg opmerking toe
    4. Replacing VTech MobiGo Touch Learning System Speaker: stap 7, afbeelding 1 van 2 Replacing VTech MobiGo Touch Learning System Speaker: stap 7, afbeelding 2 van 2
      • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
      • Make sure the speaker is the right size for the panel.
      • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
      • Do not over tighten the screws or the panel will break.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your case, follow the case instructions in reverse order.
RBansil
221 Reputatie
2 handleidingen geschreven
USF Tampa, Team 8-3, Eyestone Fall 2015 Lid van USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Leden
49 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 39
Altijd: 2,226
