Inleiding
If the vacuum cleaner only runs for a short time, the batteries are exhausted. The batteries are readily available, but you need to be good at soldering to replace them.
You will need three 18650 batteries with U-shaped soldering tabs and a voltage of 3.7 volts.
Wat je nodig hebt
Remove all attachments, leaving only the base unit.
Unscrew the five Phillips screws.
The batteries - shown here in green - are easy to see. They are held in the device by rubber buffers.
You need three 18650 batteries with U-shaped solder tabs. The higher the capacity, the longer you can vacuum. Use types with a nominal voltage of 3.7 V and a charging voltage of 4.1 V.
To be on the safe side, measure the voltage of each cell. They should all be the same.
Carefully lift out the batteries. A fuse and a thermal sensor are glued to the first and third battery.
Remove the adhesive tapes and carefully push the fuse and the thermal sensor to the side.
In the third picture you can see the thermal sensor. Note how it is guided through a groove in the rubber buffer and rests against the battery.
Now comes the main work: soldering. Get some wide heat-shrink tubing that fits over the soldering tabs.
Desolder the old batteries piece by piece - you can also pinch off the cables - and solder them to the new batteries in the same way:
Slide on suitable pieces of heat-shrink tubing before soldering.
Heat the heat-shrink tubing until it tightens against the soldering tabs.
Work through the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
