Ga door naar hoofdinhoud
Replacing Creative Zen X-Fi Speaker
Wat je nodig hebt
    1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: stap 1, afbeelding 1 van 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: stap 1, afbeelding 2 van 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: stap 1, afbeelding 3 van 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: stap 2, afbeelding 1 van 1
      • The black rubber button pad can be removed by simply picking it up.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: stap 3, afbeelding 1 van 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Speaker, Button Input Chip: stap 4, afbeelding 1 van 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: stap 5, afbeelding 1 van 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: stap 6, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: stap 7, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: stap 8, afbeelding 1 van 2 Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: stap 8, afbeelding 2 van 2
      • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
      • Once unscrewed, pick up the case and put it to the side.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: stap 9, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Westley Courchene
3.410 Reputatie
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 46
Altijd: 768
