Ga door naar hoofdinhoud
Replacing Creative Zen X-Fi Battery
Wat je nodig hebt
    1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: stap 1, afbeelding 1 van 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: stap 1, afbeelding 2 van 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: stap 1, afbeelding 3 van 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: stap 2, afbeelding 1 van 1
      • The black rubber button pad can be removed by simply picking it up.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: stap 3, afbeelding 1 van 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Battery, Button Input Chip: stap 4, afbeelding 1 van 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: stap 5, afbeelding 1 van 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: stap 6, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Vraag FixBot
      Voeg opmerking toe
    3. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: stap 7, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    1. Replacing Creative Zen X-Fi Battery, Separating the Battery: stap 8, afbeelding 1 van 1
      • Use a spudger to pry the battery from the midsection plate.
      • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: stap 9, afbeelding 1 van 2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: stap 9, afbeelding 2 van 2
      • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
      • Hold the battery wires in place so that access to the soldering joints is not blocked.
      • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
      • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Westley Courchene
3.410 Reputatie
14 handleidingen geschreven
2Gids Commentaar
very clear pictures!
John - Antwoord Deel
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 75
Altijd: 8,838
