Ga door naar hoofdinhoud
Replacing Atari Lynx Speaker
Wat je nodig hebt
  1. Replacing Atari Lynx Speaker, Atari Lynx: stap 1, afbeelding 1 van 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: stap 2, afbeelding 1 van 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: stap 3, afbeelding 1 van 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: stap 4, afbeelding 1 van 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: stap 5, afbeelding 1 van 2 Replacing Atari Lynx Speaker, Speaker: stap 5, afbeelding 2 van 2
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: stap 6, afbeelding 1 van 2 Replacing Atari Lynx Speaker: stap 6, afbeelding 2 van 2
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tyler Williams
333 Reputatie
2 handleidingen geschreven
Cal Poly, Team 1-42, Maness Winter 2014 Lid van Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Leden
16 handleidingen geschreven
2 opmerkingen
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Antwoord
What are the specs on the speaker? Size? Wattage?
gregory draudt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,448
