Wat je nodig hebt
Unlock the battery latch on the right.
Unlock the battery lock on the left.
Remove the battery pack from its slot.
Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
Check the marks indicating the direction in which the cover must be removed.
Remove the bottom cover by removing it in the direction of the markers.
Here is the RAM bar installed by default.
Locate and remove the spring blades that hold the memory module in place.
Remove the memory module (RAM).
To reassemble your device follow the instructions in reverse order
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
