Inleiding
The spur gears can wear out or be destroyed if the blender binds. The exchange is very easy.
Wat je nodig hebt
Here are the new spur gears. The spare part number at BSH is Bosch 00027660
The spur gears are fixed from above by a metal plate. This metal plate is inserted into a large plastic tab on both sides.
Gently push one of the two tabs outwards a little until the metal plate comes out of the slot.
Lift the metal plate complete with the controller and tensioner up and away and set it aside.
The two clamps for the stirring inserts are on top of the spur gears. Just lift them out
Work the steps in reverse order to reassemble your device.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
