Ga door naar hoofdinhoud
Repairing a Tear in a Tent
Wat je nodig hebt
  1. Repairing a Tear in a Tent, Sew a Ladder Stitch: stap 1, afbeelding 1 van 3 Repairing a Tear in a Tent, Sew a Ladder Stitch: stap 1, afbeelding 2 van 3 Repairing a Tear in a Tent, Sew a Ladder Stitch: stap 1, afbeelding 3 van 3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Repairing a Tear in a Tent: stap 2, afbeelding 1 van 2 Repairing a Tear in a Tent: stap 2, afbeelding 2 van 2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Repairing a Tear in a Tent: stap 3, afbeelding 1 van 2 Repairing a Tear in a Tent: stap 3, afbeelding 2 van 2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Repairing a Tear in a Tent: stap 4, afbeelding 1 van 2 Repairing a Tear in a Tent: stap 4, afbeelding 2 van 2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Repairing a Tear in a Tent: stap 5, afbeelding 1 van 3 Repairing a Tear in a Tent: stap 5, afbeelding 2 van 3 Repairing a Tear in a Tent: stap 5, afbeelding 3 van 3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
    Instead of cutting the excess thread, I leave enough length at the end to “bury” the long threads inside the repair, where they will not show and are less likely to loosen up.
    Kathleen Slamka - Antwoord
    We use a clear repair patch kind of tape to fix our tents called fixmytear repair tape. So much cheaper than paying a machinist to fix it. Apply it to both sides if you can for extra strength.
    https://www.amazon.com/Fixmytear-Magic-R...
    https://www.amazon.com/fixmytear-Magic-R...
    W731620 E - Antwoord
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
Één opmerking
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
bobhunter50023 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 268
Altijd: 7,689
