Ga door naar hoofdinhoud
Repairing Zipper Slider
Wat je nodig hebt
    1. Repairing Zipper Slider, Identifying a Bad Zipper Slider: stap 1, afbeelding 1 van 2 Repairing Zipper Slider, Identifying a Bad Zipper Slider: stap 1, afbeelding 2 van 2
      • A zipper that separates behind the zipper slider like the one shown on this tent is a very common zipper failure mode on backpacks and luggage too. It's an easy fix with a locking pliers: the goal is to carefully squeeze the top and bottom plates of the zipper slider just ever so slightly closer.
      Vraag FixBot
      Voeg opmerking toe
    2. Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: stap 2, afbeelding 1 van 2 Repairing Zipper Slider, Positioning Locking Pliers to Repair a Zipper: stap 2, afbeelding 2 van 2
      • With the locking pliers in the locked position: use the screw adjustment at the back to close on the zipper slider. (Make sure you're clamping just the zipper slider and NOT the zipper pulls or fabric.)
      • Remove the locking pliers and tighten the screw adjustment ever so slightly: a 1/16th or 1/8th of a turn should be enough: you're trying to apply the slightest pressure to both sides of the zipper slider when you re-apply it.
      • Return the locking pliers to the proper position on the zipper slider and clamp the locking mechanism down: this time, the locking pliers should lock just a little as you clamp down. Clamp the zipper slider on BOTH sides with the same setting before changing anything.
      • It might take a few tries with successively tighter settings on the locking pliers but eventually the zipper will start zipping properly again.
      Vraag FixBot
      Voeg opmerking toe
    3. Repairing Zipper Slider, Miscellaneous Zipper Slider Tips: stap 3, afbeelding 1 van 1
      • This technique even works with pitched tents, which is typically when you figure out that the zipper needs fixing. It works on luggage, backpacks, any zipper that has a metal slider.
      • If you overdo it with the locking pliers the zipper might get hard to zip. You can open the gaps on both sides in the zipper slider a little with a thin flat blade screwdriver, but it's best to work slowly and avoid that scenario.
      • Don't have locking pliers or vise grip? You can use a regular pliers in a pinch, as this person did with their backpack.
      • Someone took a video of me using this technique to repair a backpack: https://youtu.be/BhehrLek2XM
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Congratulate yourself on having saved yourself from replacing an expensive fabric item (or at least a zipper.)
17 andere personen hebben deze handleiding voltooid.
Fixit Clinic
786 Reputatie
2 handleidingen geschreven
2Gids Commentaar
Sometimes the metal in the zip will have become weakened and this method will not work. If this happens try using Zlideon zips. https://zlideon.com/ They are quite expensive but worth the money if the item is expensive or much loved. (Note I am not in any way connected to Zlideon but I have used their zipper replacements several times).
SussexDab - Antwoord Deel
Literally took two seconds to fix a zipper. THANK YOU
Emma Hochstetler - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 303
Altijd: 28,112
