Ga door naar hoofdinhoud
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
Wat je nodig hebt
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: stap 1, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: stap 1, afbeelding 2 van 2
      • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 2, afbeelding 1 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 2, afbeelding 2 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 2, afbeelding 3 van 3
      • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
      Vraag FixBot
      Voeg opmerking toe
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 3, afbeelding 1 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 3, afbeelding 2 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 3, afbeelding 3 van 3
      • When reassembling, align the notch on the battery panel with the slot on the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 4, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 4, afbeelding 2 van 2
      • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 5, afbeelding 1 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 5, afbeelding 2 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 5, afbeelding 3 van 3
      • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
      Vraag FixBot
      Voeg opmerking toe
    3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 6, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 6, afbeelding 2 van 2
      • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
      • Slide off the spring.
      Vraag FixBot
      Voeg opmerking toe
    4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 7, afbeelding 1 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 7, afbeelding 2 van 3 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 7, afbeelding 3 van 3
      • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
      • Lift up the black plastic piece.
      Vraag FixBot
      Voeg opmerking toe
    5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 8, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 8, afbeelding 2 van 2
      • Remove four 7.5mm screws with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 9, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 9, afbeelding 2 van 2
      • Remove the two buttons, noting how wires are placed for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 10, afbeelding 1 van 2 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 10, afbeelding 2 van 2
      • Lift the button board up and away to clear room for lifting the motherboard.
      • Tilt the assembly up but being wary that it is still attached to the front panel.
      Vraag FixBot
      Voeg opmerking toe
    8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 11, afbeelding 1 van 1
      • Slide the toothed slider towards you to remove.
      Vraag FixBot
      Voeg opmerking toe
    9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: stap 12, afbeelding 1 van 1
      • To reassemble, align the two black lines together by moving the belt back and forth.
      • Once aligned reinsert the toothed slider at the exact point shown.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Één andere persoon heeft deze handleiding voltooid.
Sean Webb
384 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-4, Sullivan Fall 2015 Lid van USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Leden
30 handleidingen geschreven
1Gids Commentaar
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 1,959
