Ga door naar hoofdinhoud
Repairing Tent Velcro
Wat je nodig hebt
  1. Repairing Tent Velcro, How to Sew a Whip Stitch: stap 1, afbeelding 1 van 2 Repairing Tent Velcro, How to Sew a Whip Stitch: stap 1, afbeelding 2 van 2
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. Repairing Tent Velcro: stap 2, afbeelding 1 van 3 Repairing Tent Velcro: stap 2, afbeelding 2 van 3 Repairing Tent Velcro: stap 2, afbeelding 3 van 3
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. Repairing Tent Velcro: stap 3, afbeelding 1 van 3 Repairing Tent Velcro: stap 3, afbeelding 2 van 3 Repairing Tent Velcro: stap 3, afbeelding 3 van 3
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. Repairing Tent Velcro: stap 4, afbeelding 1 van 2 Repairing Tent Velcro: stap 4, afbeelding 2 van 2
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. Repairing Tent Velcro: stap 5, afbeelding 1 van 2 Repairing Tent Velcro: stap 5, afbeelding 2 van 2
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. Repairing Tent Velcro: stap 6, afbeelding 1 van 3 Repairing Tent Velcro: stap 6, afbeelding 2 van 3 Repairing Tent Velcro: stap 6, afbeelding 3 van 3
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. Repairing Tent Velcro: stap 7, afbeelding 1 van 1
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Brittany McCrigler
89.017 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.820 handleidingen geschreven
Één opmerking
If you remembered to pack a needle, but forgot a spool of thread, and a field repair is in order: go see whether you packed any dental floss. If so, you have some hardy thread indeed, and if you bought the green minty kind, you may discover a whiff of mint now and again emanating from your repair site. I try to remember to buy the old string type of floss rather than the newer kind with flat bits, but if your needle has a big enough eye, you can thread either sort. Careful now, too thick a needle may give you threading holes larger than you want. If the repair is in a location that may leak, there are a wide variety of different things you can use to seal your sewn repair and enjoy a drier tent interior. As my preference is for canvas tents over nylon, I use beeswax, but I think a silicone spray would nicely seal a repair to nylon.
Brendan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 5,020
