Ga door naar hoofdinhoud
Repairing Puppet Strings
Wat je nodig hebt
  1. Repairing Puppet Strings, Repairing Puppet Strings: stap 1, afbeelding 1 van 1
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
    Vraag FixBot
    Voeg opmerking toe
  2. Repairing Puppet Strings: stap 2, afbeelding 1 van 1
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
    Vraag FixBot
    Voeg opmerking toe
  3. Repairing Puppet Strings: stap 3, afbeelding 1 van 1
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
    Vraag FixBot
    Voeg opmerking toe
  4. Repairing Puppet Strings: stap 4, afbeelding 1 van 2 Repairing Puppet Strings: stap 4, afbeelding 2 van 2
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
    Vraag FixBot
    Voeg opmerking toe
  5. Repairing Puppet Strings: stap 5, afbeelding 1 van 1
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
    Vraag FixBot
    Voeg opmerking toe
  6. Repairing Puppet Strings: stap 6, afbeelding 1 van 1
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
    Vraag FixBot
    Voeg opmerking toe
  7. Repairing Puppet Strings: stap 7, afbeelding 1 van 1
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
    Vraag FixBot
    Voeg opmerking toe
  8. Repairing Puppet Strings: stap 8, afbeelding 1 van 1
    • This is what your puppet should look like.
    • Happy puppet-ing!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Stephanie Gummelt
155 Reputatie
1 Handleiding geschreven
Missouri Western, Team 1-4, Adkins Fall 2015 Lid van Missouri Western, Team 1-4, Adkins Fall 2015
MWSU-ADKINS-F15S1G4
2 Leden
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 70
Altijd: 3,695
