Ga door naar hoofdinhoud
Repairing Canon PowerShot Lens Error E-18
Wat je nodig hebt
    1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: stap 1, afbeelding 1 van 1
      • Place camera lens facing upwards on the table.
      • Press and hold down the power button.
      • Simultaneously press down the shutter button.
      Vraag FixBot
      Voeg opmerking toe
    2. Repairing Canon PowerShot Lens Error E-18: stap 2, afbeelding 1 van 1
      • Replace the batteries in the camera.
      • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
      • Remove the old batteries from the camera and wait a few moments.
      • Put in a fresh set of batteries.
      • Close battery slide and power camera back on.
      Vraag FixBot
      Voeg opmerking toe
    3. Repairing Canon PowerShot Lens Error E-18: stap 3, afbeelding 1 van 1
      • Put blow dryer in the "no heat" setting prior to plugging it in.
      • Plug in and turn the blow dryer on.
      • Blow air in the gaps between the lens.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
Tim
172 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-31, Regan Winter 2011 Lid van Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Leden
12 handleidingen geschreven
1Gids Commentaar
merci! mon appareil fonctionne à nouveau
nadia.labadi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 109
Altijd: 8,811
