Ga door naar hoofdinhoud
Removing the HP Elitebook 6930p RTC (CMOS) Battery
Wat je nodig hebt
  1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: stap 1, afbeelding 1 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: stap 1, afbeelding 2 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: stap 1, afbeelding 3 van 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: stap 2, afbeelding 1 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: stap 2, afbeelding 2 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: stap 2, afbeelding 3 van 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 3, afbeelding 1 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 3, afbeelding 2 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 3, afbeelding 3 van 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 4, afbeelding 1 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 4, afbeelding 2 van 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: stap 4, afbeelding 3 van 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: stap 5, afbeelding 1 van 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: stap 5, afbeelding 2 van 2
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
Conclusie
10 andere personen hebben deze handleiding voltooid.
Richdave
32.371 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.700 handleidingen geschreven
8 opmerkingen
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - Antwoord
This didn't work for me
Depinder Bharti - Antwoord
I can't even boot
Hugo Escobar - Antwoord
cool i like the explanation
Nartey Levis - Antwoord
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 133
Altijd: 41,898
