Ga door naar hoofdinhoud
Removing the HP Elitebook 6930p WLAN Module
Wat je nodig hebt
  1. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: stap 1, afbeelding 1 van 3 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: stap 1, afbeelding 2 van 3 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: stap 1, afbeelding 3 van 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p WLAN Module, Keyboard: stap 2, afbeelding 1 van 3 Removing the HP Elitebook 6930p WLAN Module, Keyboard: stap 2, afbeelding 2 van 3 Removing the HP Elitebook 6930p WLAN Module, Keyboard: stap 2, afbeelding 3 van 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p WLAN Module: stap 3, afbeelding 1 van 3 Removing the HP Elitebook 6930p WLAN Module: stap 3, afbeelding 2 van 3 Removing the HP Elitebook 6930p WLAN Module: stap 3, afbeelding 3 van 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p WLAN Module: stap 4, afbeelding 1 van 3 Removing the HP Elitebook 6930p WLAN Module: stap 4, afbeelding 2 van 3 Removing the HP Elitebook 6930p WLAN Module: stap 4, afbeelding 3 van 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: stap 5, afbeelding 1 van 3 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: stap 5, afbeelding 2 van 3 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: stap 5, afbeelding 3 van 3
    • Locate the WLAN module
    • Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
    • The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order. there are coloured tabs on the wires!
    • Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
    • With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Richdave
32.287 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.525 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 8,168
