Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the large button on the top of the device. Push down on the button and slide the cover away from the button. The battery removal tab may pop up.
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Grab the red pull tab and pull down to unlock the latch. Pull the battery out. Pull the battery out.
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. locate the four hex screws on the bottom of the device. Use a T6 hex bit  from the iFixit precision screwdriver set to remove the four screws. Use a T6 hex bit  from the iFixit precision screwdriver set to remove the four screws.
    • locate the four hex screws on the bottom of the device.
    • Use a T6 hex bit from the iFixit precision screwdriver set to remove the four screws.
  4. To remove the next two T6 screws, locate the button at the top of the back of the device. Around the button, there is a cover that protects the two screws. To remove the cover insert a flathead screwdriver or thumb nail and lift up until cover is removed.
    • To remove the next two T6 screws, locate the button at the top of the back of the device.
    • Around the button, there is a cover that protects the two screws.
    • To remove the cover insert a flathead screwdriver or thumb nail and lift up until cover is removed.
  5. After removing the cover, use the T6 screwdriver and remove the screws. After removing the cover, use the T6 screwdriver and remove the screws. After removing the cover, use the T6 screwdriver and remove the screws.
    • After removing the cover, use the T6 screwdriver and remove the screws.
  6. With the 6 screws removed, the back cover can be removed revealing the backside of the motherboard (PCB Logic Board). Pull up on the back cover from the device. Locate the power button.
    • With the 6 screws removed, the back cover can be removed revealing the backside of the motherboard (PCB Logic Board).
    • Pull up on the back cover from the device.
    • Locate the power button.
  7. Remove the power button from the left. Locate the antenna extension connector on the right and remove the plastic piece. Locate the antenna extension connector on the right and remove the plastic piece.
    • Remove the power button from the left.
    • Locate the antenna extension connector on the right and remove the plastic piece.
  8. After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece. Simply pull up on the PCB Logic Board to remove. CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
    • After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece.
    • Simply pull up on the PCB Logic Board to remove.
    • CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Scott Byer
61 Reputatie
5 handleidingen geschreven
Clemson, Team 1-2, Benson Spring 2012 Lid van Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Leden
9 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 36
Altijd: 2,316
