Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the large button on the top of the device.
Push down on the button and slide the cover away from the button.
Grab the red pull tab and pull down to unlock the latch.
Pull the battery out.
Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
Remove the two screws under the button using the T6 Torx screwdriver.
Remove the plastic antenna extension connector on the right side of the device.
Pull up on the motherboard to remove it from the device.
Één andere persoon heeft deze handleiding voltooid.
