Ga door naar hoofdinhoud
Remove the Write Protect Screw
Wat je nodig hebt
  1. Remove the Write Protect Screw, Remove the rubber pads: stap 1, afbeelding 1 van 2 Remove the Write Protect Screw, Remove the rubber pads: stap 1, afbeelding 2 van 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
    Vraag FixBot
    Voeg opmerking toe
  2. Remove the Write Protect Screw, Removing the bottom panel: stap 2, afbeelding 1 van 3 Remove the Write Protect Screw, Removing the bottom panel: stap 2, afbeelding 2 van 3 Remove the Write Protect Screw, Removing the bottom panel: stap 2, afbeelding 3 van 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
    Vraag FixBot
    Voeg opmerking toe
  3. Remove the Write Protect Screw, Pop it open: stap 3, afbeelding 1 van 2 Remove the Write Protect Screw, Pop it open: stap 3, afbeelding 2 van 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
    Vraag FixBot
    Voeg opmerking toe
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): stap 4, afbeelding 1 van 2 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): stap 4, afbeelding 2 van 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
16 andere personen hebben deze handleiding voltooid.
Kevin Fessler
1.857 Reputatie
4 handleidingen geschreven
4Gids Commentaar
removing this will allow me to boot and install windows?
john Akday - Antwoord Deel
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy - Antwoord Deel
You will find more information here:
https://coolstar.org/chromebook/windows-...
Lino Bolivar - Antwoord Deel
Acer R752TN write protect screw location?
Fredrik Løvås - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 206
Altijd: 46,029
