Ga door naar hoofdinhoud
Remove the Screen
Wat je nodig hebt
    1. Remove the Screen, Remove Screws: stap 1, afbeelding 1 van 3 Remove the Screen, Remove Screws: stap 1, afbeelding 2 van 3 Remove the Screen, Remove Screws: stap 1, afbeelding 3 van 3
      • Remove the screws from the bottom, right, and left side of camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove the Screen, Remove back: stap 2, afbeelding 1 van 1
      • Remove the back of the camera, this may require force.
      Vraag FixBot
      Voeg opmerking toe
    1. Remove the Screen, Remove Metal Bracket: stap 3, afbeelding 1 van 1
      • Unscrew the right metal bracket of the viewing lens
      Vraag FixBot
      Voeg opmerking toe
    1. Remove the Screen, Remove front of camera: stap 4, afbeelding 1 van 2 Remove the Screen, Remove front of camera: stap 4, afbeelding 2 van 2
      • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove the Screen: stap 5, afbeelding 1 van 2 Remove the Screen: stap 5, afbeelding 2 van 2
      • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
      Vraag FixBot
      Voeg opmerking toe
    3. Remove the Screen: stap 6, afbeelding 1 van 1
      • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
      Vraag FixBot
      Voeg opmerking toe
    4. Remove the Screen: stap 7, afbeelding 1 van 1
      • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
      Vraag FixBot
      Voeg opmerking toe
    1. Remove the Screen, Remove the Screen: stap 8, afbeelding 1 van 1
      • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove the Screen: stap 9, afbeelding 1 van 1
      • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
      Vraag FixBot
      Voeg opmerking toe
    3. Remove the Screen: stap 10, afbeelding 1 van 1
      • Pull out the red wire and white wire attaching the screen to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Remove the Screen: stap 11, afbeelding 1 van 1
      • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Melissa
246 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-2, Buehl Spring 2013 Lid van Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Leden
55 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 831
