Ga door naar hoofdinhoud
Remove Stuck Disc from Samsung P241
Wat je nodig hebt
    1. Remove Stuck Disc from Samsung P241, Top Case: stap 1, afbeelding 1 van 2 Remove Stuck Disc from Samsung P241, Top Case: stap 1, afbeelding 2 van 2
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove Stuck Disc from Samsung P241: stap 2, afbeelding 1 van 2 Remove Stuck Disc from Samsung P241: stap 2, afbeelding 2 van 2
      • Pull the top cover towards you until you can lift it up and off.
      Vraag FixBot
      Voeg opmerking toe
    1. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: stap 3, afbeelding 1 van 1
      • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove Stuck Disc from Samsung P241: stap 4, afbeelding 1 van 1
      • Locate the four rectangular holes in the top of the black plastic disc drive.
      Vraag FixBot
      Voeg opmerking toe
    3. Remove Stuck Disc from Samsung P241: stap 5, afbeelding 1 van 2 Remove Stuck Disc from Samsung P241: stap 5, afbeelding 2 van 2
      • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
      Vraag FixBot
      Voeg opmerking toe
    4. Remove Stuck Disc from Samsung P241: stap 6, afbeelding 1 van 1
      • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
      • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
      Vraag FixBot
      Voeg opmerking toe
    5. Remove Stuck Disc from Samsung P241: stap 7, afbeelding 1 van 1
      • Now repeat this process, unclipping the catches on the other side.
      Vraag FixBot
      Voeg opmerking toe
    6. Remove Stuck Disc from Samsung P241: stap 8, afbeelding 1 van 3 Remove Stuck Disc from Samsung P241: stap 8, afbeelding 2 van 3 Remove Stuck Disc from Samsung P241: stap 8, afbeelding 3 van 3
      • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lawrence Smith
126 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-7, Forte Winter 2011 Lid van Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 37
Altijd: 4,553
