Ga door naar hoofdinhoud
Remove Solid-State Drive (SSD)
Wat je nodig hebt
  1. Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: stap 1, afbeelding 1 van 2 Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: stap 1, afbeelding 2 van 2
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    Vraag FixBot
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    Vraag FixBot
  2. Remove Solid-State Drive (SSD), Disconnect battery cable: stap 3, afbeelding 1 van 1
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    Vraag FixBot
  3. Remove Solid-State Drive (SSD), Remove the system board mylar: stap 4, afbeelding 1 van 2 Remove Solid-State Drive (SSD), Remove the system board mylar: stap 4, afbeelding 2 van 2
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    Vraag FixBot
  4. Remove Solid-State Drive (SSD), Remove the solid-state drive (SSD) shielding: stap 5, afbeelding 1 van 1
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    Vraag FixBot
  5. Remove Solid-State Drive (SSD), Unscrew Solid-State Drives (SSD): stap 6, afbeelding 1 van 1
    • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
    Vraag FixBot
    • Remove each SSD by pulling it away from the slot.
    • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
    Vraag FixBot
Conclusie
johann beda
3.428 Reputatie
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 95
