Ga door naar hoofdinhoud
Remove IBM WorkPad c3 Battery
Wat je nodig hebt
    1. Remove IBM WorkPad c3 Battery, Back Case: stap 1, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery, Back Case: stap 1, afbeelding 2 van 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      Vraag FixBot
      Voeg opmerking toe
    2. Remove IBM WorkPad c3 Battery: stap 2, afbeelding 1 van 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      Vraag FixBot
      Voeg opmerking toe
    3. Remove IBM WorkPad c3 Battery: stap 3, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery: stap 3, afbeelding 2 van 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      Vraag FixBot
      Voeg opmerking toe
    1. Remove IBM WorkPad c3 Battery, Battery: stap 4, afbeelding 1 van 1
      • Remove the yellow tape that is covering the battery connector
      Vraag FixBot
      Voeg opmerking toe
    2. Remove IBM WorkPad c3 Battery: stap 5, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the tweezers, carefully disconnect the battery cable from the port
      Vraag FixBot
      Voeg opmerking toe
    3. Remove IBM WorkPad c3 Battery: stap 6, afbeelding 1 van 2 Remove IBM WorkPad c3 Battery: stap 6, afbeelding 2 van 2
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emily Falkenstein
75 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-35, Regan Fall 2010 Lid van Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 56
Altijd: 4,913
