Inleiding
These instructions show how to remove the top cover.
Wat je nodig hebt
Depending on the model, the steam tap/water spout must be removed, there are slight differences here.
Pull out the plastic clip on the steam nozzle.
Pull the steam nozzle out towards you.
If you haven't already done so, also detach the right-hand cover on the water tank.
Remove the four Phillips screws securing the top cover.
Lift the top cover up a bit. That might be a bit sticky.
If there is a cup warmer, then unscrew the nut SW7 with which the two green-yellow cables are connected and loosen it. The two brown cables on the other side can stay if you just put the cover on top.
Place the top cover on top, or remove it entirely.
Work the steps in reverse order to reassemble your device.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
