Ga door naar hoofdinhoud
Remove Battery
Wat je nodig hebt
  1. Remove Battery, Remove screws from bottom of laptop.: stap 1, afbeelding 1 van 2 Remove Battery, Remove screws from bottom of laptop.: stap 1, afbeelding 2 van 2
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    Vraag FixBot
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    Vraag FixBot
  2. Remove Battery, Disconnect battery cable: stap 3, afbeelding 1 van 1
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    Vraag FixBot
  3. Remove Battery, Remove battery screws: stap 4, afbeelding 1 van 1
    • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    Vraag FixBot
    • Lift out the battery.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
johann beda
3.428 Reputatie
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 93
