Ga door naar hoofdinhoud
Remington MB4040 Thermal Switch Replacement
Wat je nodig hebt
    1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 1 van 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 2 van 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: stap 1, afbeelding 3 van 3
      • Press the black button below the blade to remove the blade.
      Vraag FixBot
      Voeg opmerking toe
    2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: stap 2, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: stap 2, afbeelding 2 van 2
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 1 van 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 2 van 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: stap 3, afbeelding 3 van 3
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      Vraag FixBot
      Voeg opmerking toe
    4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): stap 4, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): stap 4, afbeelding 2 van 2
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: stap 5, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: stap 5, afbeelding 2 van 2
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      Vraag FixBot
      Voeg opmerking toe
    1. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: stap 6, afbeelding 1 van 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: stap 6, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    2. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: stap 7, afbeelding 1 van 1
      • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
      • Use a low temperature RTV to readhere the thermal switch to the battery.
      • Remove the soldering holding the thermal switch to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Cameron Carnahan
1.112 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-5, Blackwell Winter 2015 Lid van USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 3,357
