Ga door naar hoofdinhoud
Redmi Note 4 Screen and bracket Replacement
Wat je nodig hebt
    • take out the sim tray
    • unscrew the two pentalobe P2 screws under the phone
    • use a suction cup and a pryer to open the phone(Very Heavy!)
    Vraag FixBot
    Voeg opmerking toe
  1. Redmi Note 4 Screen and bracket Replacement: stap 2, afbeelding 1 van 1
    • fingerprint cable
    • screen cable(display only)
    • power cble
    • buttons cable
    Vraag FixBot
    Voeg opmerking toe
    • unplug the power cable. it should be attached just by pushing , so just lift it.
    • unplug the screen cable. they are ZIF connectors.
    • you can test the new screen here, just by plugging the new screen cable, then the power cable
    • unplug the button cable, also ZIFs.
    • remove the battery using a hard rubber spatula.(it's got handle like IPhone's, but with china quality)
    • pry from the left bottom side. NEVER from the right side, or you might damage a cable.
    • remove the remaining glue from the battery, and re-tape it inside the white lines with tapes like TESA 2mm.
    • unplug antenna wire running down right side of phone to bottom mainboard.
    Vraag FixBot
    Voeg opmerking toe
  2. Redmi Note 4 Screen and bracket Replacement: stap 4, afbeelding 1 van 2 Redmi Note 4 Screen and bracket Replacement: stap 4, afbeelding 2 van 2
    • remove these phillips #0 screws on the upper board(forgot the number and the place, please add)
    • remove the vibration motor cover
    • remove the upper motherboard
    Vraag FixBot
    Voeg opmerking toe
  3. Redmi Note 4 Screen and bracket Replacement: stap 5, afbeelding 1 van 1
    • remove the phillips #0 screw from the lower casing
    • they're black, so easy to recognize
    • unplug all connectors(need photo)
    • use a hair dryer to heat the lower board(it's got glue)
    • be careful not to use force, the board is very fragile. If you feel hard to remove, heat it again.
    Vraag FixBot
    Voeg opmerking toe
    • Heat the borders of your screen to loosen the glue.
    • use a suction cup to open it.
    • the cables from the screen should all be detached at this moment
    • remove all the remaining glue from the plastic bracket (I mean all)
    Vraag FixBot
    Voeg opmerking toe
    • use tapes like TESA 2mm to re-glue the bracket.
    • you'll need to glue all the borders, but not around cameras, speakers, and proximity sensors.
    • Check the video I've linked to see where to glue.
    Vraag FixBot
    Voeg opmerking toe
    • reverse the steps and you should be good to go!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
sub ari
470 Reputatie
1 Handleiding geschreven
7Gids Commentaar
Where's the video? I can't find it on this page.
Roman Belyakovsky - Antwoord Deel
Looks like it's been removed.
http://v.youku.com/v_show/id_XMTc3NDA5ND...
Here you are.
sub ari - Antwoord Deel
Redmi Note 4 lcd Jumper ways
Please!
KhinMaungphyo - Antwoord Deel
Where can I find the replacement screen for this model??
The screen I ordered have the connectors the wrong place and I can't find any replacement screen with BOTH wires on the bottom …
valerie langlois - Antwoord Deel
you could buy a new screen in taobao
牛头与画像 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 114
Altijd: 28,584
