Ga door naar hoofdinhoud
Razer Phone Motherboard Replacement
Wat je nodig hebt
  1. Razer Phone Motherboard Replacement, Display Assembly: stap 1, afbeelding 1 van 3 Razer Phone Motherboard Replacement, Display Assembly: stap 1, afbeelding 2 van 3 Razer Phone Motherboard Replacement, Display Assembly: stap 1, afbeelding 3 van 3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Razer Phone Motherboard Replacement: stap 2, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Razer Phone Motherboard Replacement: stap 3, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 3, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Razer Phone Motherboard Replacement: stap 4, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Razer Phone Motherboard Replacement: stap 5, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 5, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    Vraag FixBot
    Voeg opmerking toe
  6. Razer Phone Motherboard Replacement: stap 6, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    Vraag FixBot
    Voeg opmerking toe
  7. Razer Phone Motherboard Replacement, Battery: stap 7, afbeelding 1 van 3 Razer Phone Motherboard Replacement, Battery: stap 7, afbeelding 2 van 3 Razer Phone Motherboard Replacement, Battery: stap 7, afbeelding 3 van 3
    • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
    • Remove the connector.
    Vraag FixBot
    Voeg opmerking toe
  8. Razer Phone Motherboard Replacement: stap 8, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
    • Grab the bracket with the tweezers and remove it.
    Vraag FixBot
    Voeg opmerking toe
  9. Razer Phone Motherboard Replacement: stap 9, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 9, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Peel off and pull out the elastic tabs at the bottom of the battery.
    Vraag FixBot
    Voeg opmerking toe
  10. Razer Phone Motherboard Replacement: stap 10, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Carefully use the Jimmy to wedge the battery out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  11. Razer Phone Motherboard Replacement, Rear Camera: stap 11, afbeelding 1 van 2 Razer Phone Motherboard Replacement, Rear Camera: stap 11, afbeelding 2 van 2
    • Remove the one 2.5 mm screw with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  12. Razer Phone Motherboard Replacement: stap 12, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 12, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Remove the protective peel covering the rear cameras using your hands.
    Vraag FixBot
    Voeg opmerking toe
  13. Razer Phone Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use the tweezers to remove the white tab connector.
    Vraag FixBot
    Voeg opmerking toe
  14. Razer Phone Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Grab and remove the metal tab with the tweezers.
    Vraag FixBot
    Voeg opmerking toe
  15. Razer Phone Motherboard Replacement: stap 15, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 15, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Grab the connectors with the tweezers and gently lift the connectors loose.
    Vraag FixBot
    Voeg opmerking toe
  16. Razer Phone Motherboard Replacement: stap 16, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 16, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  17. Razer Phone Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Remove the one 2.5 mm screw underneath the connectors with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  18. Razer Phone Motherboard Replacement: stap 18, afbeelding 1 van 3 Razer Phone Motherboard Replacement: stap 18, afbeelding 2 van 3 Razer Phone Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Grab the loose connectors with a tweezer and gently remove the rear camera unit from the phone.
    Vraag FixBot
    Voeg opmerking toe
  19. Razer Phone Motherboard Replacement, Motherboard: stap 19, afbeelding 1 van 1
    • Grab and remove the blue connector with the tweezers.
    Vraag FixBot
    Voeg opmerking toe
  20. Razer Phone Motherboard Replacement: stap 20, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Remove the five 1 mm screws holding down the gold antenna line brackets to the motherboard using the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  21. Razer Phone Motherboard Replacement: stap 21, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 21, afbeelding 2 van 2
    • Remove the 2.5 mm screw next to the front-facing camera with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  22. Razer Phone Motherboard Replacement: stap 22, afbeelding 1 van 2 Razer Phone Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Remove the four gold antenna line brackets with the tweezers.
    Vraag FixBot
    Voeg opmerking toe
  23. Razer Phone Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Using the tweezers remove the SIM card tray from the body of the phone.
    Vraag FixBot
    Voeg opmerking toe
  24. Razer Phone Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Carefully lift up the motherboard away from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Todd
188 Reputatie
1 Handleiding geschreven
Cal Poly, Team S19-G6, White Winter 2019 Lid van Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 38
Altijd: 2,111
