Ga door naar hoofdinhoud
Razer Phone Display Assembly Replacement
Wat je nodig hebt
  1. Razer Phone Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 3 Razer Phone Display Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 3 Razer Phone Display Assembly Replacement, Display Assembly: stap 1, afbeelding 3 van 3
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Razer Phone Display Assembly Replacement: stap 2, afbeelding 1 van 2 Razer Phone Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Razer Phone Display Assembly Replacement: stap 3, afbeelding 1 van 3 Razer Phone Display Assembly Replacement: stap 3, afbeelding 2 van 3 Razer Phone Display Assembly Replacement: stap 3, afbeelding 3 van 3
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Razer Phone Display Assembly Replacement: stap 4, afbeelding 1 van 2 Razer Phone Display Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Razer Phone Display Assembly Replacement: stap 5, afbeelding 1 van 3 Razer Phone Display Assembly Replacement: stap 5, afbeelding 2 van 3 Razer Phone Display Assembly Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
    Vraag FixBot
    Voeg opmerking toe
  6. Razer Phone Display Assembly Replacement: stap 6, afbeelding 1 van 2 Razer Phone Display Assembly Replacement: stap 6, afbeelding 2 van 2
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sebastian Barragan
438 Reputatie
1 Handleiding geschreven
Cal Poly, Team S19-G6, White Winter 2019 Lid van Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
4 Leden
20 handleidingen geschreven
14Gids Commentaar
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - Antwoord Deel
Double sided tape.
Lucano - Antwoord Deel
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - Antwoord Deel
Search on eBay. Phones are often parted out there.
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 88
Altijd: 16,886
