Ga door naar hoofdinhoud
Razer Phone Charging Port Replacement
Wat je nodig hebt
    1. Razer Phone Charging Port Replacement, Display Assembly: stap 1, afbeelding 1 van 3 Razer Phone Charging Port Replacement, Display Assembly: stap 1, afbeelding 2 van 3 Razer Phone Charging Port Replacement, Display Assembly: stap 1, afbeelding 3 van 3
      • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
      • Peel off the plastic speaker grill to reveal the screws.
      • Heating up the plastic grills make them easier to remove.
      • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Phone Charging Port Replacement: stap 2, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 2, afbeelding 2 van 2
      • Pry the top plastic grill off with the metal spudger and reveal the screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Phone Charging Port Replacement: stap 3, afbeelding 1 van 3 Razer Phone Charging Port Replacement: stap 3, afbeelding 2 van 3 Razer Phone Charging Port Replacement: stap 3, afbeelding 3 van 3
      • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
      • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Razer Phone Charging Port Replacement: stap 4, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 4, afbeelding 2 van 2
      • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
      • Lift the display assembly away from the other half of the phone.
      Vraag FixBot
      Voeg opmerking toe
    5. Razer Phone Charging Port Replacement: stap 5, afbeelding 1 van 3 Razer Phone Charging Port Replacement: stap 5, afbeelding 2 van 3 Razer Phone Charging Port Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
      • Peel back the metallic shielding over the connector using tweezers.
      • Remove the metal bracket connector.
      Vraag FixBot
      Voeg opmerking toe
    6. Razer Phone Charging Port Replacement: stap 6, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 6, afbeelding 2 van 2
      • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Phone Charging Port Replacement, Battery: stap 7, afbeelding 1 van 3 Razer Phone Charging Port Replacement, Battery: stap 7, afbeelding 2 van 3 Razer Phone Charging Port Replacement, Battery: stap 7, afbeelding 3 van 3
      • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
      • Remove the connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Phone Charging Port Replacement: stap 8, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 8, afbeelding 2 van 2
      • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
      • Grab the bracket with the tweezers and remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Phone Charging Port Replacement: stap 9, afbeelding 1 van 3 Razer Phone Charging Port Replacement: stap 9, afbeelding 2 van 3 Razer Phone Charging Port Replacement: stap 9, afbeelding 3 van 3
      • Peel off and pull out the elastic tabs at the bottom of the battery.
      Vraag FixBot
      Voeg opmerking toe
    4. Razer Phone Charging Port Replacement: stap 10, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 10, afbeelding 2 van 2
      • Carefully use the Jimmy to wedge the battery out of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Phone Charging Port Replacement, Charging Port: stap 11, afbeelding 1 van 2 Razer Phone Charging Port Replacement, Charging Port: stap 11, afbeelding 2 van 2
      • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
      • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Phone Charging Port Replacement: stap 12, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 12, afbeelding 2 van 2
      • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Phone Charging Port Replacement: stap 13, afbeelding 1 van 2 Razer Phone Charging Port Replacement: stap 13, afbeelding 2 van 2
      • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
      • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
      Vraag FixBot
      Voeg opmerking toe
    4. Razer Phone Charging Port Replacement: stap 14, afbeelding 1 van 1
      • Using the tweezers, grab the detached charging port and ribbon.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Bryan
777 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G6, White Winter 2019 Lid van Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
4 Leden
25 handleidingen geschreven
10Gids Commentaar
Who i can find one replacement…pls a link
Flims LP - Antwoord Deel
Search it on Amazon.c
HolaSoy Guapo - Antwoord Deel
hi how much you guys charge for the charging port thanks
johnny rodas - Antwoord Deel
Does this tutorial also work for the Razer phone 2?
Derrick - Antwoord Deel
Nah, even step one looks different for me.
Edsknife - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 121
Altijd: 27,050
