Inleiding
This guide is for replacing the scroll wheel on the Razer Naga Trinity gaming mouse (RZ01-0241). If the mouse is used for an extended period of time, the scroll wheel can become dirty or start to wear out, negatively effecting the user’s experience. A common problem that may occur is the rubber on the scroll wheel deteriorating from the oils on the hand and friction. Another problem is dirt collecting between the optical encoder and the scroll wheel (Optical Encoder Replacement). This will hinder the response time and accuracy of the user’s input. There are no special skills required to perform this replacement.
Wat je nodig hebt
Remove the mouse's feet using the opening pick.
Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
Then pull the LED controller board upwards and out.
Gereedschap gebruikt in deze stap:Halberd Spudger$2.99
Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
Gereedschap gebruikt in deze stap:Tweezers$3.99
Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
