Inleiding
Guide to replace the cable that powers and connects the headset to the user's computer or gaming console. These cables may fray after long periods of use or break after being mishandled and need to be replaced. See our troubleshooting guide.
Make sure to completely unplug your headset before attempting this guide. As well as working on an anti-static surface.
Wat je nodig hebt
After unscrewing the motherboard, gently pull it away from the headset and turn it over.
4 opmerkingen
I know that Kraken line that have USB connection, have two types. Plug (as described on this guide) and 5-pin Welded wire.
Anyone knows what Kraken models have the Plug wire? and if the Kraken V2 7.1 have the same kind of wire of this guide?
Thank you!
i found a replacement USB Charging cable For Razer Kraken BT Kitty Edition/Ultimate Edition Headphone
