Ga door naar hoofdinhoud
Razer Kraken Ultimate Microphone Replacement
Wat je nodig hebt
  1. Razer Kraken Ultimate Microphone Replacement, Ear Pads: stap 1, afbeelding 1 van 3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: stap 1, afbeelding 2 van 3 Razer Kraken Ultimate Microphone Replacement, Ear Pads: stap 1, afbeelding 3 van 3
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Microphone Replacement: stap 2, afbeelding 1 van 2 Razer Kraken Ultimate Microphone Replacement: stap 2, afbeelding 2 van 2
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Microphone Replacement: stap 3, afbeelding 1 van 2 Razer Kraken Ultimate Microphone Replacement: stap 3, afbeelding 2 van 2
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Microphone Replacement, Speaker: stap 4, afbeelding 1 van 3 Razer Kraken Ultimate Microphone Replacement, Speaker: stap 4, afbeelding 2 van 3 Razer Kraken Ultimate Microphone Replacement, Speaker: stap 4, afbeelding 3 van 3
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Microphone Replacement: stap 5, afbeelding 1 van 2 Razer Kraken Ultimate Microphone Replacement: stap 5, afbeelding 2 van 2
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Microphone Replacement: stap 6, afbeelding 1 van 2 Razer Kraken Ultimate Microphone Replacement: stap 6, afbeelding 2 van 2
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Microphone Replacement, Microphone: stap 7, afbeelding 1 van 3 Razer Kraken Ultimate Microphone Replacement, Microphone: stap 7, afbeelding 2 van 3 Razer Kraken Ultimate Microphone Replacement, Microphone: stap 7, afbeelding 3 van 3
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Microphone Replacement: stap 8, afbeelding 1 van 1
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Microphone Replacement: stap 9, afbeelding 1 van 2 Razer Kraken Ultimate Microphone Replacement: stap 9, afbeelding 2 van 2
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Microphone Replacement: stap 10, afbeelding 1 van 1
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
Conclusie
Tucker Murphy
115 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-4, Petersen Fall 2022 Lid van UMass Dartmouth, Team 1-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G4
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 560
