Ga door naar hoofdinhoud
Razer Huntsman Tournament Edition Key Switch Replacement
Wat je nodig hebt
  1. Razer Huntsman Tournament Edition Key Switch Replacement, Keycaps: stap 1, afbeelding 1 van 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
    Vraag FixBot
    Voeg opmerking toe
  2. Razer Huntsman Tournament Edition Key Switch Replacement: stap 2, afbeelding 1 van 2 Razer Huntsman Tournament Edition Key Switch Replacement: stap 2, afbeelding 2 van 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
    Vraag FixBot
    Voeg opmerking toe
  3. Razer Huntsman Tournament Edition Key Switch Replacement: stap 3, afbeelding 1 van 3 Razer Huntsman Tournament Edition Key Switch Replacement: stap 3, afbeelding 2 van 3 Razer Huntsman Tournament Edition Key Switch Replacement: stap 3, afbeelding 3 van 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
    Vraag FixBot
    Voeg opmerking toe
  4. Razer Huntsman Tournament Edition Key Switch Replacement, Chassis: stap 4, afbeelding 1 van 1
    • Remove all of the keycaps with a keycap puller.
    Vraag FixBot
    Voeg opmerking toe
  5. Razer Huntsman Tournament Edition Key Switch Replacement: stap 5, afbeelding 1 van 3 Razer Huntsman Tournament Edition Key Switch Replacement: stap 5, afbeelding 2 van 3 Razer Huntsman Tournament Edition Key Switch Replacement: stap 5, afbeelding 3 van 3
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
    Vraag FixBot
    Voeg opmerking toe
  6. Razer Huntsman Tournament Edition Key Switch Replacement: stap 6, afbeelding 1 van 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
    Vraag FixBot
    Voeg opmerking toe
  7. Razer Huntsman Tournament Edition Key Switch Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
    Vraag FixBot
    Voeg opmerking toe
  8. Razer Huntsman Tournament Edition Key Switch Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the internal cable.
    Vraag FixBot
    Voeg opmerking toe
  9. Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: stap 9, afbeelding 1 van 2 Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: stap 9, afbeelding 2 van 2
    • Gently push the key switch off of the mainboard with your thumb.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Joseph O'Dowd
419 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Lid van UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 64
Altijd: 2,817
