Ga door naar hoofdinhoud
Razer Blade Stealth 2017 Fan Replacement
Wat je nodig hebt
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Razer Blade Stealth 2017 Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: stap 3, afbeelding 1 van 2 Razer Blade Stealth 2017 Fan Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
    Do you have to remove the battery before swapping the wifi card? Is disconnecting the power not enough?
    Charles Tsai - Antwoord
    Hi Charles,
    If you’re swapping the Wi-Fi card, you don’t need to remove the battery. Disconnecting it will suffice.
    Arthur Shi -
    Are two of these screws shorter than the other four? And if so, where do the two shorter screws go?
    James Spinella - Antwoord
    Looks like the two shorter screws go where the trackpad is!
  5. Razer Blade Stealth 2017 Fan Replacement: stap 5, afbeelding 1 van 2 Razer Blade Stealth 2017 Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
    After removing the 6 screws securing the battery, mine does not come out easily. There is resistance, and I don't wanna forcefully pull it out. Is it supposed to be easy to pick up and take out or is there some sort of tape holding it down from the bottom?
    kairos - Antwoord
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: stap 6, afbeelding 1 van 2 Razer Blade Stealth 2017 Fan Replacement, Fan: stap 6, afbeelding 2 van 2
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: stap 8, afbeelding 1 van 3 Razer Blade Stealth 2017 Fan Replacement: stap 8, afbeelding 2 van 3 Razer Blade Stealth 2017 Fan Replacement: stap 8, afbeelding 3 van 3
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: stap 9, afbeelding 1 van 3 Razer Blade Stealth 2017 Fan Replacement: stap 9, afbeelding 2 van 3 Razer Blade Stealth 2017 Fan Replacement: stap 9, afbeelding 3 van 3
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: stap 10, afbeelding 1 van 2 Razer Blade Stealth 2017 Fan Replacement: stap 10, afbeelding 2 van 2
    • Use a plastic spudger to slide the fans out of the case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Helene Willits
776 Reputatie
6 handleidingen geschreven
Cal Poly, Team S11-G3, Regan Fall 2019 Lid van Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Leden
7 handleidingen geschreven
Één opmerking
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 2,469
