Inleiding
Use this guide to remove or replace the back cover on your Razer Blade 15" (2018) laptop.
Wat je nodig hebt
Rotate your laptop so the screen hinge is farthest from you.
Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Insert your pick up to 10 mm (0.4 in) deep.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
