Ga door naar hoofdinhoud
Razer Basilisk V3 Scroll Wheel Assembly Replacement
Wat je nodig hebt
    1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Skates: stap 1, afbeelding 1 van 1
      • Locate the highlighted white skates on the bottom of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 2, afbeelding 1 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 2, afbeelding 2 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 2, afbeelding 3 van 3
      • Heat the skate using a heat gun or hair dryer.
      • Using the pointy end of the spudger pry away a corner of the skate.
      • If the adhesive does not pull away easily, heat the skate more.
      • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
      • Repeat these steps for each of the skates.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Backplate: stap 3, afbeelding 1 van 1
      • Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
      • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 4, afbeelding 1 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 4, afbeelding 2 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 4, afbeelding 3 van 3
      • Heat the label gently with a heat gun or hair dryer.
      • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
      • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 5, afbeelding 1 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 5, afbeelding 2 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 5, afbeelding 3 van 3
      • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
      • Be cautious of the clips that may break during this process.
      • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
      • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: stap 6, afbeelding 1 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: stap 6, afbeelding 2 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: stap 6, afbeelding 3 van 3
      • Use the flat end of the spudger to pop-out the scroll wheel assembly.
      • Make sure you are careful when removing the scroll wheel since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 7, afbeelding 1 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 7, afbeelding 2 van 3 Razer Basilisk V3 Scroll Wheel Assembly Replacement: stap 7, afbeelding 3 van 3
      • Pull up on the top half of the cable connector and pull the cable from the connector.
      • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Mary Quin
306 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-2, Santin Spring 2024 Lid van UMass Dartmouth, Team 1-2, Santin Spring 2024
UMASSD-SANTIN-S24S1G2
2 Leden
9 handleidingen geschreven
1Gids Commentaar
Where can I buy this complete spare part?
Van4ESss - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 163
Afgelopen 30 dagen: 718
Altijd: 12,106
