Ga door naar hoofdinhoud
RIDGID R84015 X2 Speed Switch Replacement
Wat je nodig hebt
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 1 van 2 RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 2 van 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: stap 3, afbeelding 1 van 2 RIDGID R84015 X2 Speed Switch Replacement: stap 3, afbeelding 2 van 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: stap 4, afbeelding 1 van 1
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: stap 5, afbeelding 1 van 2 RIDGID R84015 X2 Speed Switch Replacement: stap 5, afbeelding 2 van 2
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Conclusie
Evan Long
262 Reputatie
4 handleidingen geschreven
Cal Poly, Team 15-48, Garner Spring 2010 Lid van Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 3,639
