Ga door naar hoofdinhoud
RIDGID R84015 X2 Planetary Gear Replacement Guide
Wat je nodig hebt
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 1 van 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: stap 1, afbeelding 2 van 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 2, afbeelding 1 van 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 3, afbeelding 1 van 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 3, afbeelding 2 van 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: stap 4, afbeelding 1 van 1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 5, afbeelding 1 van 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 5, afbeelding 2 van 2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 6, afbeelding 1 van 1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 7, afbeelding 1 van 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: stap 7, afbeelding 2 van 2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Evan Long
262 Reputatie
4 handleidingen geschreven
Cal Poly, Team 15-48, Garner Spring 2010 Lid van Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Leden
10 handleidingen geschreven
Één opmerking
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 6,257
