Ga door naar hoofdinhoud
REL T5 Repaste transistors
    1. REL T5 Repaste transistors, Repaste heatsink and pads: stap 1, afbeelding 1 van 3 REL T5 Repaste transistors, Repaste heatsink and pads: stap 1, afbeelding 2 van 3 REL T5 Repaste transistors, Repaste heatsink and pads: stap 1, afbeelding 3 van 3
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      Vraag FixBot
      Voeg opmerking toe
    2. REL T5 Repaste transistors: stap 2, afbeelding 1 van 1
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      • TODO image of mounted board
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jasper van Zuijlen
1.044 Reputatie
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 15
