Ga door naar hoofdinhoud
RCA RP3715A Tuning Wheel Replacement
Wat je nodig hebt
    1. RCA RP3715A Tuning Wheel Replacement, Reaching the battery terminal.: stap 1, afbeelding 1 van 2 RCA RP3715A Tuning Wheel Replacement, Reaching the battery terminal.: stap 1, afbeelding 2 van 2
      • Push down on the clip to release pressure. The pull off the plastic cover.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RP3715A Tuning Wheel Replacement, Replacing the battery: stap 2, afbeelding 1 van 1
      • Remove the 9-volt battery from the battery terminal.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA RP3715A Tuning Wheel Replacement, Getting inside the device.: stap 3, afbeelding 1 van 1
      • Take out the six screws located on the back of the device.
      • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
      • Three screws are located on the back panel. One is located inside the battery carriage.
      • Two screws are located on the on the back panel on the bottom left and right side.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: stap 4, afbeelding 1 van 3 RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: stap 4, afbeelding 2 van 3 RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: stap 4, afbeelding 3 van 3
      • Remove the 10 mm Phillip's #1 screw.
      • Then remove the metal reinforcement.
      Vraag FixBot
      Voeg opmerking toe
    3. RCA RP3715A Tuning Wheel Replacement: stap 5, afbeelding 1 van 2 RCA RP3715A Tuning Wheel Replacement: stap 5, afbeelding 2 van 2
      • Using flathead screwdriver undo the release tabs.
      Vraag FixBot
      Voeg opmerking toe
    4. RCA RP3715A Tuning Wheel Replacement: stap 6, afbeelding 1 van 3 RCA RP3715A Tuning Wheel Replacement: stap 6, afbeelding 2 van 3 RCA RP3715A Tuning Wheel Replacement: stap 6, afbeelding 3 van 3
      • Pry the release tabs with a spudger.
      • Start with back of the device on the topside.
      Vraag FixBot
      Voeg opmerking toe
    5. RCA RP3715A Tuning Wheel Replacement: stap 7, afbeelding 1 van 2 RCA RP3715A Tuning Wheel Replacement: stap 7, afbeelding 2 van 2
      • Pry open both tabs to remove the topside of the clock.
      Vraag FixBot
      Voeg opmerking toe
    6. RCA RP3715A Tuning Wheel Replacement, Speaker Replacement: stap 8, afbeelding 1 van 1
      • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA RP3715A Tuning Wheel Replacement, Motherboard: stap 9, afbeelding 1 van 2 RCA RP3715A Tuning Wheel Replacement, Motherboard: stap 9, afbeelding 2 van 2
      • asd
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RP3715A Tuning Wheel Replacement, Removing the top part of motherboard: stap 10, afbeelding 1 van 1
      • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
      Vraag FixBot
      Voeg opmerking toe
    3. RCA RP3715A Tuning Wheel Replacement, Removing the side part of motherboard: stap 11, afbeelding 1 van 1
      • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
      Vraag FixBot
      Voeg opmerking toe
    4. RCA RP3715A Tuning Wheel Replacement: stap 12, afbeelding 1 van 1
      • Remove the transformer by pulling back the release tab shown.
      Vraag FixBot
      Voeg opmerking toe
    5. RCA RP3715A Tuning Wheel Replacement: stap 13, afbeelding 1 van 1
      • Pull the battery terminal through the whole shown.
      Vraag FixBot
      Voeg opmerking toe
    6. RCA RP3715A Tuning Wheel Replacement, Lift the digital screen: stap 14, afbeelding 1 van 1
      • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
      Vraag FixBot
      Voeg opmerking toe
    7. RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: stap 15, afbeelding 1 van 3 RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: stap 15, afbeelding 2 van 3 RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: stap 15, afbeelding 3 van 3
      • Remove the motherboard from the frame using the illustration shown.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA RP3715A Tuning Wheel Replacement, Replacing the tuning wheel: stap 16, afbeelding 1 van 1
      • Lift up the gray tuning wheel and replace it with the new one.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alexander Trowell
222 Reputatie
2 handleidingen geschreven
USF Tampa, Team 10-5, Brown Fall 2014 Lid van USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 539
