Ga door naar hoofdinhoud
RCA RCT6773W22 Motherboard Replacement
Wat je nodig hebt
  1. RCA RCT6773W22 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 RCA RCT6773W22 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Motherboard Replacement: stap 2, afbeelding 1 van 3 RCA RCT6773W22 Motherboard Replacement: stap 2, afbeelding 2 van 3 RCA RCT6773W22 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Motherboard Replacement: stap 3, afbeelding 1 van 3 RCA RCT6773W22 Motherboard Replacement: stap 3, afbeelding 2 van 3 RCA RCT6773W22 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Motherboard Replacement, Speaker: stap 4, afbeelding 1 van 3 RCA RCT6773W22 Motherboard Replacement, Speaker: stap 4, afbeelding 2 van 3 RCA RCT6773W22 Motherboard Replacement, Speaker: stap 4, afbeelding 3 van 3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
  5. RCA RCT6773W22 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Use the spudger to lift up the black tab on all three ZIF connectors.
    • Use tweezers to remove the ribbon cables from the zift connectors.
  6. RCA RCT6773W22 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use Phillips #000 screwdriver to remove the three 3mm screws on the motherboard.
  7. RCA RCT6773W22 Motherboard Replacement: stap 7, afbeelding 1 van 2 RCA RCT6773W22 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger or plastic opening tool to lift up the motherboard.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kelsea Weber
19.873 Reputatie
32 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 2,971
