Ga door naar hoofdinhoud
RCA RCT6272W23 Rear Camera Replacement
Wat je nodig hebt
  1. RCA RCT6272W23 Rear Camera Replacement, Case: stap 1, afbeelding 1 van 2 RCA RCT6272W23 Rear Camera Replacement, Case: stap 1, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Rear Camera Replacement: stap 2, afbeelding 1 van 2 RCA RCT6272W23 Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Rear Camera Replacement, Motherboard: stap 3, afbeelding 1 van 3 RCA RCT6272W23 Rear Camera Replacement, Motherboard: stap 3, afbeelding 2 van 3 RCA RCT6272W23 Rear Camera Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Rear Camera Replacement: stap 4, afbeelding 1 van 1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Rear Camera Replacement: stap 5, afbeelding 1 van 2 RCA RCT6272W23 Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Rear Camera Replacement, Rear Camera: stap 7, afbeelding 1 van 1
    • Using a spudger, gently pry off the camera from the back of the display
Conclusie
Stephen Radachy
819 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 1-5, Lauer Spring 2015 Lid van Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 345
