Ga door naar hoofdinhoud
RCA RCT6272W23 Battery Replacement
Wat je nodig hebt
  1. RCA RCT6272W23 Battery Replacement, Case: stap 1, afbeelding 1 van 2 RCA RCT6272W23 Battery Replacement, Case: stap 1, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: stap 2, afbeelding 1 van 2 RCA RCT6272W23 Battery Replacement: stap 2, afbeelding 2 van 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: stap 4, afbeelding 1 van 1
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Stephen Radachy
819 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 1-5, Lauer Spring 2015 Lid van Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 5,340
