Ga door naar hoofdinhoud
RCA 8 Apollo Screen Replacement
Wat je nodig hebt
    1. RCA 8 Apollo Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA 8 Apollo Screen Replacement: stap 2, afbeelding 1 van 2 RCA 8 Apollo Screen Replacement: stap 2, afbeelding 2 van 2
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Vraag FixBot
      Voeg opmerking toe
    3. RCA 8 Apollo Screen Replacement: stap 3, afbeelding 1 van 2 RCA 8 Apollo Screen Replacement: stap 3, afbeelding 2 van 2
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA 8 Apollo Screen Replacement, Display Assembly: stap 4, afbeelding 1 van 3 RCA 8 Apollo Screen Replacement, Display Assembly: stap 4, afbeelding 2 van 3 RCA 8 Apollo Screen Replacement, Display Assembly: stap 4, afbeelding 3 van 3
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA 8 Apollo Screen Replacement: stap 5, afbeelding 1 van 1
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. RCA 8 Apollo Screen Replacement: stap 6, afbeelding 1 van 1
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA 8 Apollo Screen Replacement, Screen: stap 7, afbeelding 1 van 3 RCA 8 Apollo Screen Replacement, Screen: stap 7, afbeelding 2 van 3 RCA 8 Apollo Screen Replacement, Screen: stap 7, afbeelding 3 van 3
      • Remove the screw from the bottom left of the tablet.
      • Place an opening tool under the screen.
      • Pry up the screen and it will unclip from the clips holding the screen down.
      • Avoid using too much force to prevent the glass from breaking.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
McKenna Shipper
123 Reputatie
1 Handleiding geschreven
Casper College, Team 1-1, Lareau Spring 2024 Lid van Casper College, Team 1-1, Lareau Spring 2024
CASC-LAREAU-S24S1G1
3 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 264
