Ga door naar hoofdinhoud
RAM memory upgrade / replacement
Wat je nodig hebt
  1. RAM memory upgrade / replacement, Remove the battery: stap 1, afbeelding 1 van 3 RAM memory upgrade / replacement, Remove the battery: stap 1, afbeelding 2 van 3 RAM memory upgrade / replacement, Remove the battery: stap 1, afbeelding 3 van 3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
    Vraag FixBot
    Voeg opmerking toe
  2. RAM memory upgrade / replacement, Remove the captive screw of the service door: stap 2, afbeelding 1 van 1
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. RAM memory upgrade / replacement, Remove the service door: stap 3, afbeelding 1 van 3 RAM memory upgrade / replacement, Remove the service door: stap 3, afbeelding 2 van 3 RAM memory upgrade / replacement, Remove the service door: stap 3, afbeelding 3 van 3
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
    Vraag FixBot
    Voeg opmerking toe
  4. RAM memory upgrade / replacement, Identify the components: stap 4, afbeelding 1 van 1
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
    Vraag FixBot
    Voeg opmerking toe
  5. RAM memory upgrade / replacement, Offset the protective flap's boomerang-like effect: stap 5, afbeelding 1 van 1
    • Without bending it, gently turn the RAM modules' protective flap to the left and stick it to the base enclosure with a piece of adhesive tape.
    Vraag FixBot
    Voeg opmerking toe
  6. RAM memory upgrade / replacement, Dismount the top memory module: stap 6, afbeelding 1 van 3 RAM memory upgrade / replacement, Dismount the top memory module: stap 6, afbeelding 2 van 3 RAM memory upgrade / replacement, Dismount the top memory module: stap 6, afbeelding 3 van 3
    • Take the spudger and place it over the bottom retaining arm so that the former can have a good grip on the latter. When you feel the grip, straightly towards yourself and quite forcefully, push the retaining arm off. You are going to hear a tiny click when the arm will be detached.
    • Repeat the last operation on the top retaining arm. This time pushing it off towards the opposite direction: as soon as you released the second arm also, the memory module will tilt up immediately.
    • The top memory module is now released, and, if you're grounded, you can take it out of its slot. Grab the module as it is shown in pic#3 and - maintaining its inclination and making it lightly and repeatedly swing as a pendulum (btw left and right, as the bent blue arrow tries to show) - pull it out and put it away.
    Vraag FixBot
    Voeg opmerking toe
  7. RAM memory upgrade / replacement, Dismount the bottom memory module: stap 7, afbeelding 1 van 1
    • Repeat the same process on the bottom memory module in order to remove that one too.
    Vraag FixBot
    Voeg opmerking toe
  8. RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: stap 8, afbeelding 1 van 3 RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: stap 8, afbeelding 2 van 3 RAM memory upgrade / replacement, Mount one of the new modules inside the bottom slot: stap 8, afbeelding 3 van 3
    • Are you grounded? If yes, take one of the new memory modules and align it with the connector by the correct side: the close-to-the-middle indentation of the module has to face the highlighted pin.
    • Then, keeping it tilted and carrying on the "pendulum" movement, gently push the module inside the slot. STOP when you feel you can't go any further: the new memory module should be now tilted and totally inside the connector - as it is shown in pic#2 - and the indentation of the module should almost be attached to the centring pin.
    • Once that the module is so positioned, gently press it down pushing it in the middle with your fingers until you hear a loud click: that sound means that the retaining arms have correctly grabbed the module and that the latter one has been successfully inserted!
    Vraag FixBot
    Voeg opmerking toe
  9. RAM memory upgrade / replacement, Mount the second module on top of the previous one: stap 9, afbeelding 1 van 3 RAM memory upgrade / replacement, Mount the second module on top of the previous one: stap 9, afbeelding 2 van 3 RAM memory upgrade / replacement, Mount the second module on top of the previous one: stap 9, afbeelding 3 van 3
    • Repeat the same process in order to insert the remaining module and it's done!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
You have successfully replaced the RAM memory! Congratulations :) Now remove the tape and reassemble the service door and the battery. Enjoy the new piece of hardware, cheers!
Roberto Bartolacci
1.548 Reputatie
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 76
Altijd: 3,525
