Inleiding
Here you will learn how to change the RAM on the PC why! W253EU.
Wat je nodig hebt
Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Locate the two memory modules.
Release the locking spring on both sides of the module.
Now lift the module with its connector slightly.
To reassemble, follow the instructions in reverse order.
Met dank aan deze vertalers:
100%
oldturkey03 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
