Inleiding
From time to time, it is essential to check the brewing group to keep the aroma of the coffee good. Unpleasant coffee fat can settle under the two brewing sieves. The sealing ring may need to be replaced. You don't necessarily have to open the case (then skip the steps), but this is very simple and makes the job easier. Spare parts are not so easy to obtain, e.g. www.quickmill.at is a good address.
Wat je nodig hebt
Open the front cover
Unscrew the coffee spout on the thumbscrew with your fingers.
Clean thoroughly the coffee spout
The upper piston is generally not as dirty as the lower one, as the fresh water flows in here.
Unscrew the Phillips screw on the brewing sieve and remove the brewing sieve.
Clean the plunger very thoroughly.
Clean the brewing sieve very thoroughly. Leave it in machine detergent for some time. Check if all holes are free, if necessary you can open them gently with a needle tip.
The lower plunger has coffee flowing through it and is therefore more contaminated. Loosen the Phillips screw, then it will break into three parts: strainer, shaft and piston with chamber.
Put everything in machine detergent for some time and then clean it very thoroughly. The piston chamber must not contain any more coffee grease, the holes in the sieve must be free.
You can keep the piston rod very thinly lubricated with a food-safe lubricant, but this is not absolutely necessary.
Complete the steps in reverse order to reassemble the device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
